To keep you update , the red box has been sent to Sasa in Italy .
I send it to a wrong adress in Roma so he managed to recover the parcel ...
A huge THANK to him for his help and his kindness.
He has reprogrammed the rb without any issues .
The bike run like a charm now , his V6 version is very well balance .
The power delivery is smooth, the idling is perfect and high rpm is reving fast .
We feel the bike run more rich as it should.
Thank for the work .
Concerning the big bore kit , power and torque has increase a lot , especially in the range between 4000 and 5000 rpm, the bike is reving like a mx bike now .
In the other hand i think that the engine has lost the elasticity of the long course due the square course .
I will open a new tread on my feeling about the modifications .
Have you tried an air filter clean up?Hello ,
No update
The bike is running on map 3 as they are no difference between maps on my feeling
Have you tried to run it without the air filter and the cap (just for a short test ride)?Have you tried an air filter clean up?
Thanks for this step-by-step tutorial on how to install the updated software. While it all seems quite straightforward, I am unsure of whether I am required to turn on the power to my Himalayan (turn the key) while I upload to software from my laptop via the USB cable.May I inquire where you have bought it? I have no records of selling another one to France.
You should not use the box as is assuming it is in its original state (which of course I dont know because I have no idea how you got it)
First you download the V5 map from here:
Filename: 477 EXPERIMENTAL MAP V5.0 RC.zip
then unzip the map file inside the ZIP container. I dont know what system you use so you have figure that out by yourself.
(Later you can ask @Sasa for the V6 - but get it to run on 5 first to understand the process)
Connect the red box to your bike's harness replacing the stock ECU. Then via USB to your Laptop.
After you connected the red box to your computer via usb cable is the software recognizing the red box? When you click here does it turn green and "on"?
if YES then you click on Open here:
select the map file (the one you have just downloaded and extracted from the zip file) by double clicking it
Now the values in the window change (if they don't you did it wrong)
then you click here:
Now you need to calibrate the TPS value - click on this:
Open the throttle fully 3 times in a row
Now you should be all set. (I hope I havnt forgotten anything - I have no red box handy at the moment so the last part is from memory)
you can take the red box to your computer at home and load the maps there, thats what I have done while I had a BS4. Bigger screen. easier handling. make sure you burn to the eprom the changes before you disconnect.Thanks for this step-by-step tutorial on how to install the updated software. While it all seems quite straightforward, I am unsure of whether I am required to turn on the power to my Himalayan (turn the key) while I upload to software from my laptop via the USB cable.
Thanks. All went smoothly.you can take the red box to your computer at home and load the maps there, thats what I have done while I had a BS4. Bigger screen. easier handling. make sure you burn to the eprom the changes before you disconnect.
If you just want to upload the software the key can stay off, the laptop will power the RedBOX.Thanks for this step-by-step tutorial on how to install the updated software. While it all seems quite straightforward, I am unsure of whether I am required to turn on the power to my Himalayan (turn the key) while I upload to software from my laptop via the USB cable.
I calibrated the TPS with the key off and saw the throttle position sensor meter move within the software when I did so. The engine runs fine now, but I was wondering if I would have gotten different results on the TPS calibration if the key (and bike 12v power) were on during the calibration process?If you just want to upload the software the key can stay off, the laptop will power the RedBOX.
When you have to calibrate the TPS you can turn the key on (NOT THE ENGINE) and do the procedure.
Please read my message above. I said calibrate the TPS with ign key on, not off.I calibrated the TPS with the key off and saw the throttle position sensor meter move within the software when I did so. The engine runs fine now, but I was wondering if I would have gotten different results on the TPS calibration if the key (and bike 12v power) were on during the calibration process?
I know this was a long time in the past and the issue has since been solved, but when I am not pretending to be cool with Motorcycles I am an IT guy and thought this might be helpful if someone else finds this issue.Here somes pictures
