did you change the disc as well?The caliper is a 30-32 mm as compared to our stock 26mm.
Nope. The scram 440 also comes with a 300mm disc like the Himalayan. So I plan to first check the new caliper with the stock himalayan disc.did you change the disc as well?
Yes I recall. That is the first post from Google search that lead me to the old forum, and introduced me to Himalayan Tools.the 300mm floating Brembo disc used in the 535 conti fits - I have used it on my BS3 Hima. fantastic results with the Brembo caliper going along with it
Yeah, that sucks! I wonder if they do this on purpose or if they just don't care. I see this with so many different parts that almost fit but not quite. They should learn from BMW which had a policy (in the past) where you could exchange 90% or parts between models.Slightly bigger gap between the two mounting holes and also bigger sized bolts.
