The OEM ground cable from the battery consists of two ground wires. One wire is for the frame ground and the other wire goes directly to one of the starter motor mounting bolts. The one that goes to the starter motor should be cut right at the terminal that is on the negative post and removed from the starter motor mounting bolt. I replaced that ground wire with a 24” long 8 gauge wire with 6mm ring terminals on each end. It is important that this ground wire runs directly from the negative battery post to the starter motor mounting bolt.Got the Relay, and now I've got a question:
Looking at the OEM Relay, I initially see 3 Red Wires, and I believe these to correspond to what Himmie's Diagram shows to be F, B, M. Cool.
What I Don't understand is what was discussed earlier about the Ground Wire. I Totally See why the skinny little Wire that is there now would/could be inadequate, but since it 'Goes Somewhere' past the Connector, how did you solve this? I'm thinking that I could go Directly to Neg-Battery or the the Frame but with a Heavier Wire. Not sure if I should reutilize the Connector that sits in between or not...
I've gotta pick up some Heavier Gauge Wire before digging into this so I'll await an answer or two?
TIA
Let me know if that makes sense to you or not.
