Because of the Nature of this Forum ie , no one reads it so I dont get any bad feed back 🙃
I share this thought without fear of some tosser taking offence
What Happened Yesterday? Why did I not get 50% more to the Point!
So an investigation is being undertaken and all should be revealed next week.
In the meantime I present some evidence , the Data collected from this Dyno run could result in an improved Map bringing the 50% closer to my reach
Okay the Pictures explained,
Top left, shows that the Horses (
32.6 of them!) start to drop at 6600RPM ( Red Line is 6500! )
I have no respect for the line. It goes to 8000 and I think there is a Horse or 2 hiding up there.
It also shows the
AFR going high in the corresponding revs, could the Horses want more Oats
Top right shows 4 maps are very close if that is what you want take from it.
But look at the Torque up to
38 Nm ! right smack in the middle where you ride this Bike at 3000 to 5000rpm
Bottom is of course the Software showing the Map as taken from the ECU before the run and shall be used in evidence
48% increase with just 8% more Displacement, so perhaps Bigger is Better, if you want to take in the scenery and eat others dust you dont need to this and there is a dedicated Forum for that as well
