It might be early days and possible clickbait, but while having the left side engine cover removed during the 500 conversion, i thought i might as well investigate the gear indicator sensor for a 6th gear. Nothing fancy as you would expect from RE, just a pin that rotates with the shift drum that provides ground for the contacts on the sensor.
The good news is that it has a contact for a 6th gear position, the bad news is that it doesn't work on the display... Providing ground to the 6th contact results in a 5 on the dashboard. I have a BS3 and while the sensor(wiring) on the BS4 is different i am not expecting a different outcome. The sensor could be used probably for an aftermarket gear indicator
