ABS removal
If you fully remove the ABS will the ABS warning light be on all the time? Any way to (permanently) turn it off? Thanks.
I did not have a stock speedo when removed mine, but I believe that light should not blink since you are getting rid of everything. Finding the wire and unplugging it from the main connector at the speedometer could keep it off if it blinks.
