DUM DUM BULLET
So the PT4 is not a work of art!
Program is quite limited and requires being plugged into to the unit to function at all.
But the O2 sensor is still in play so it seems to be doing a great job of trimming in closed loop.
I have just populated the fuel "map" with 75% increase leaving the bottom line at 50%.
Doesent knock and pulls well, I was so happy I put it back on the bench and changed out the oem cam for the stage 2, quick job if you don't use the special tools and don't drop the cam chain or a bolt :cool:
And here's the surprise ,compression has increased bucket loads.
Compared to the same build with an OEM Cam, which was 185.
So rings have bedded in?
Valves are open longer so more air gets sucked in?
I did it wrong last time?
Or the gauge is buggered?
I vote for this option.
there is no logic in any change of compression due to a cam change. if "more stuff is in the chamber" where actually a valid argument then compression would change every time you change mapping.
and the rings have already been run in (if you use my set)
cheap china shit?
So you discount the extra lift and duration of the Cam has an effect on volumetric efficiency?
Stauff gauges would be my choice but I doubt it's the gauge.
Probably Chinese but what isn't?
Your are saying the rings were already bedded in but the assembly was fitted to a different engine so they would not have been so.
Since running this set I have had starting issues and low voltage mils( engine warning lights) as a result so I am not so sure.
Anyhow it will be getting topped up with 98ron tomorrow.
Re-assessment in the dum dum build.
I, as usual jumped steps and missed some.
The leap to the 84mm piston was a leap to far at the time.
Previously with just a 60cc increase in displacement I had been getting good results and do not think I reached the full potential before going to higher displacement.
As I have already installed the PT4 and am in no hurry to remove it! I will utilise that for moderate ignition advances and fuel increases and hopefully learn enough to determine if a bit more is worth while.
So reinstalling 411 kit, only 1 base gasket, stock head, Stage 2 cam, stock header, decat pipe and Indoori HK muffler .
As it stands, so the Bullet has the 411 kit Stage 2 Cam, Indoori muffler( with home made baffle), OEM airfilter with high flow cover.
PT4 and Fx pro plus.
Air Fuel Ratio gauge would indicate it runs quite well( if I knew the gauge was calibrated).
The fluctuations shown on the gauge usually about 1 point or less depending on throttle input etc, the Fx when set to a number above 3( ie off) reduces the fluctuations and it would seem to be integral with the PT4.
I state that also because I have eventually found a Dyno tuner who will work with and has knowledge of the PT.
When making a Booking he asked if I had the FX fitted as well as the PT, saying it was necessary for Closed Loop tuning.
He also must be in demand, I have the next available slot in ,,,,,, October 27th!
Can I wait that long or will I live that long was my first thought, or will I still have 411cc? I might get bored!
Haven't asked the price, I can wait for that surprise :confused:
High Flow airfilter cover, hacksaw a Belt sander and my Dremel changed the OEM( forever).
I doubt this engine will ever use more air than can get through this.
This what is commonly called a Hotdog muffler, at 45mm( 1 and 3/4 inch ) the inlet takes the stock graphite gasket and oem clamp is used along with the oem bracket ( that involved welding 2 8mm nuts.
Sound is good and the price is right, A$56 including freight.
Cant stop fiddling, so I refitted the Delkovic system designed? for the meteor after welding in an O2 bung for my AFR meter.
Previously it started to run out of grunt before 5000rpm now it goes to 5500rpm and starts to run out of grunt!
Bit noisy even with the baffle but seems to me that it is breathing a bit better.
This on an OEM Cam so perhaps a bit more lift and duration will improve it more.
Hopefully I will have the stage 2 Cam back in for the Dyno Tune on the 27th( not far off now). Been busy building these things,
Chinese ( of course) and quite well made.
This is what I have fitted to my Bullet.
funny perspective. where are the loudspeakers and the HiFi?
that chinese micro pickup looks interesting, is it street legal?
Not street legal here but EPA approved!
It must be designed for Farmers, it has grease nipples 😁
Top of the range has GPS and SOS function for roll over!
Rings keep on bedding in it would seem, this is the latest compression reading as taken this morning dead cold.
Compare to previous reading 1800kms earlier.
So from a new build there is a increase in compression pressure of 10psi.
Meaning I have run it well:unsure:
Long awaited Dyno tune this Monday.
Build as it is now,
84mm piston, same size as the 500kit, even Baxter's call it 500! 😁 But for the sake of accuracy to be precise it is 84mm x 85.8 displacing
475cc,
Reshaped combustion chamber/head,
This is OEM cira 500kms( i just had to wait for the first service:ROFLMAO:)
20250416_172450.jpg little bit of porting( little compared to the combustion chamber mods:ROFLMAO:)
OEM Cam, PT4 plus Fx pro+, Delkevic header ( much bigger ID!) 2 inch, 52mm slip on Muffler.
Air filter cover is OEM that I have Butchered with stock( and original air filter)
Since partially covered with a paint tin lid cut on angle held with hot glue( sorry no pic) PT4 and Fx pro+, .
2 teeth down at the back and 1 tooth up at the front.
Stock tyres, good chain of less than 1500kms.
I am expecting my wallet to be lighter by the end of the day but not much else.
It will be an improvement over stock at least, ( low bar!) and regardless it is a great bike that I feel much more comfortable on than the Himalayans were.
Prior to the Dyno run, I thought I should check the Cam timing with the Factory tools as the last 3 times I just looked at the piston rising with a USB Cam and set by eye.
So by doing by eye I got it that close that I don't think I'll bother using the special tools again!
Bit early for its 3rd Oil change and 3rd filter, but that stuff is cheap.
Long post, but it has been a long wait for me! Whether I set a record or not it has been a labour of love
Make what you can of this, Blue line is my attempt at tuning, Red line is the Experts, cost A$700 for this difference ;)
17 hp for a 500?? also: you built a 2 cylinder version?
OK compared to the earlier 11.8 showed in your 350 reference its a lot.
It may all make sense when I get to my old Dyno shop for a run. It showed 19 HP there as a 410.
Need the ECU Reflashed but nobody seems to be doing that at a price I can afford :)
Bike seems to run a bit better, time will tell.
In order to get a Base line Dyno I have reverted back to stock for a run this Tuesday.
Being a bit lazy I did not change back the gearing which is 1 up at the front and 2 down at the back.
Expecting it to be rather sluggish in stock form with higher gearing, I am surprised how well it pulls, says a lot for stock Torque.
Because the stock muffler is made the way it is, it doesn't take a sniffer tube at the Dyno shop meaning I will not be getting fueling data and so will not be aware of the change in AFR when I fit a Camshaft for the following run.
To make this fit I had to get the O2 sensor very close to the front of the Cat pipe even had to notch the Header pipe.
Meter now show a lot of high 14s and low 15s, good for fuel consumption bit not so good for power.
Made it look a little bit better for tomorrow's run ;)
