J-Engine 410cc Thread
Question. In the Service manual for the 350 Classic, it shows torquing the cylinder bolts to 15nm, then 35nm and then an additional 150 degrees.
Am I reading that correctly?
And I'm reusing my bolts, I have upgraded other motors in the past reusing head and cylinder bolts without any problems.
Anyone run into any issues doing the same procedure?
The bolts stretch apparently, I would follow the book.
we (in India) re-use the bolts several times. Never had an issue. But they are cheap. So its more an availability issue than a money issue.
I have a bunch on order since a while (not for me, for a "concerned" friend) and the distributor takes his sweet time.
YES, I had never heard about this tool, so when Ranjeet tried to explain it in his version of English I still did not get it but seeing the picture it becomes clear. Basically an alternative to a torque wrench - right?
Not exactly a replacement, just enables an accurate number of degrees to be turned after a certain point is reached.
Whether by tension wrench or previous marks made.
OK thanx, in parallel I also asked chatgpt and here is that answer:
If you're referring to angular torque applied in degrees, it sounds like you're talking about a tool like a torque angle gauge or a torque angle wrench.
These tools are used to apply a specific angle of rotation after a certain initial torque has been set, often in applications like assembling engines or other mechanical components.
Here's how it works:
  1. Initial Torque: You first apply a specified torque using a regular torque wrench to get the fastener snug.
  2. Angle Specification: After reaching the initial torque, you then use the torque angle gauge or wrench to turn the fastener an additional specified number of degrees (for example, 90 degrees).
This method is crucial for ensuring proper clamping force and alignment in high-stress applications.
I finished the bike today. Cranked her up and noticed she sounded a little more chuggy.? After while she sounded better.
Got the bike out for a 25 mile ride.
Definitely a noticeable difference in the mid range, feels like there is more torque, I hooked up small digital tach and kept the RPMs down under 3500.
I did keep the Power Cam and FuelX Lite installed.
I'm at a mile above sea level, I rode a little into the mountains to get a sense of power and it did feel better in the twisty's.
If your at sea level, one might feel a great bit more power off the line.
So far, I'm happy with the results.
On a side note, I think the supplier should offer a cam chain tensioner gasket with the kit and option to buy new cylinder bolts to meet the RE requirements as per manual.
I'll update again in a few hundred miles.
My turn to do the 410 mod, bike ( Bullet) is nearly ready for its first Dyno to get a Base line.
I do the first Dyno because I want to know what my bike makes on the said Dyno machine, although maybe this figure has been produced by others I feel it is not relevant to my purposes as all Dyno machines read slightly different and I want an exact figure to relate my future mods to.
First job for my purposes is to "match" the Combustion chamber to the larger bore.
Head is sat upside-down and the new cylinder positioned using just the Dowels.
Scribing the head with something sharp I now have the diameter marked on the Head( in this case I am using a new head so I can keep riding).
I use a rotary drill, a Dremel would do the job but this unit is more powerful and will outlast a Dremel also it has a 3 jaw chuckle unlike a Dremel.
First cut
Finished job
My next job will be to remove the Valves( I left them in to protect the Valve Seats ) and recut the seats to my own preference.
I prefer to use the interference angle system and will use a hand held cutter to Crown and Throat the seat to position the contact area.
My opinion on Lapping is mostly disputed by keyboard warriors on some forums and I choose to ignore their bleating and use my system.
Pics of the Valves/Seats to follow.
Before
And after
Ports de dagged and matched to the valve inserts.
De shrouded the Valves,
Made a bespoke( not often get to use that word!) Valve spring compressor.
Using oil paint from the Craft store ( Bearing Blue is not easy to obtain these days ) I have smeared a small amount on the Valve face.
Then using what some may refer to as a Lapping tool I have inserted the Valve into the Head and rotated it leaving behind an indication of seating contact area.
The Valve also shows an indication.
Basically where they touch the Blue comes off and stays on the Head/Valve seat.
I now have to wait for the correct sized (6mm) arbor to arrive that will enable me to change the position of the contact on the Valve.
My preference ( although what is shown here is adequate ) is for a thinner contact line and one that is closer to the Stem which will in effect raise the Valve out of the Seat.
This tool holds the cutting tip that will "Crown" ( cut the top ) of the Seat, as you may be able to determine,the tool is inserted into the Valve Guide with various different angled cutters held at 90deg.
The Seat contact area is cut to 45deg so I will be using a 30deg cutting angle to Crown the seat and bring the Valve contact area closer to the valve stem.
Had I wanted to go the other way I would be using a larger angle such as 70deg and "Throating" the seat.
When finished I will NOT be lapping the valve with grinding paste !
Another advantage of a thinner seat contact area is that the Pressure holding the Valve to the seat is greater.
Same Force on less Area equals more Pressure.
P = F/A can't argue with Physics ;)
Butt Dyno test, Greenmount hill average incline 7 degrees.
Last time I did this a few weeks ago on the 350 I was unable to maintain the 80kph speed limit in 5th gear and was forced to change down to 4th.
Today with 411cc I was able to accelerate in 5th and hold the limit!
A percentage increase of ?
Dyno in a couple of weeks. :cool:
5psi up is better than 5psi down.
Maybe the rings are bedding in?
Rides good!
Recieved my 410 kit a few moths ago and fitted it within a couple of days of arrival.Everything went smoothly.The bike idled a little roughly for a couple of minutes but then settled down .Now upon starting cold the bike idles as normal.Fitted the Kent Camshaft,decat exhaust downpipe,open air filter cover with standard filter and Fuel X pro plus all at the time of fitting the 410 kit.Due to weather conditions and health conditions I only got to ride the bike a couple of days ago.I kept the revs below 4000 for the first few miles then went to 4500 a few times for short periods.I'm very impressed with the difference.Bike pulls much better and is a lot more responsive.Very pleased.Went to go for a ride the next day and noticed the head gasket leaking exhaust gasses while getting ready to go riding.Spoke with Sam, it seems to be an issue with the torque figures I used to tighten down the head.These figures have been updated so anyone fitting the kit be sure the figures you use are the correct ones.Big thank you to Sam his customer service is excellent.He's sending me a new gasket and i'll order new head bolts.These are not necessary but they are cheap and easily got.Overall i'm extremely happy with the kit and the performance.I can't stress enough how good Sams customer service is.He responded very quickly to my messages and is sending out the new gasket immediately free of charge.That's proper customer service.Thank You Sam
Beauty is in the eye of the beholder. I for one like the Hunter looks over the antiquated Bullet. Its a fresh impression and if "helped" to a little more umpf it also is a fun drive. I guess the Bullet would drive much the same, unless the ECUs are very differently mapped (not likely). So that leaves the look. Modern and fresh over an antique from the pre-war period (and I do not mean the current war).
I bought the first two Guerillas that came into Northern Ireland.I rode one and put 300 miles on it and then parked it.I prefer my Hunter.The secound Guerilla is sitting never ridden since the dealer delivered it.Now with the 410 kit on my Hunter it's my bike of choice.I think even my Classic 350 will sit unused now too.Maybe the Classic 350 will become a Classic 410
make it a 500, you'll need the PT4 as well and I suggest the Kent cam too - a bit pricey but if you sell the unused Guerrilla it may just be enough dough :cool:
I use a digital torque wrench, evenly criss cross the bolts up to 25 nm then in 2.5nm rises goes around till 35nm, have a Coffee and then up to 37!
Worked for me!
