What Powertronic needed
Bloodshotjoe
Hi
I have a 2021 Himalayan 411, I like it a lot and decided to give it some upgrades. So far I’ve installed a cam, DNA filter and open cover, added a tooth to the gearbox sprocket, and a fuelx lite.
I’d like to ad a full Delkevic exhaust in the near future.
After reading and learning some more I fear the fuelx lite is not sufficient.
Is the fuelx lite sufficient for these upgrades? If not what do I need to get the best performance out of the above setup?
If it matters I typically ride at about 9000ft/2750m elevation.
Thank you all for your expertise
bS4 OR bS6
out of the above setup you get almost no add. performance. even fuelx pro will not give you that. realistically and if you know how to program it for a stock engine the red box or PT V4 would give some more power but the real deal is cam or BB kit or both - all else is just propaganda.
bS4 OR bS6
Hi
I have what I’ve been calling a euro4. I’m confused because you say I need a cam but I have one installed already. I’m not really interested in a big bore.
To reiterate, completed upgrades are:
-Cam
-Open airbox and filter
-gearbox sprocket
-fuelx lite
I’d like to go full exhaust in the future.
With my cam and other upgrades what electronics do I need to have it run optimally.
Thank you
sorry, I overlooked the cam bit. but what I said remains true. any real changes you will need a ECU you can manipulate. fuelx, pro or not, is not an ecu, just a o2 sensor cheat. so if you have bs4 I suggest the red box bc it is a real ecu (swaps for the stock one) but if you have a bs6 your options are limited to PT V4 which is only piggyback. all this is explained here at great length, suggest do use the search function.
great I dont need to create another thread for this. so regarding the ECU my path is to go with 440 ecu and fuel x lite. but there is one more thing i saw an ad from RaceDynamics about their new piggyback ecu R200 has anybody looked into this
