Himalayan fork bars and front suspension components on Meteor 350 fork
borja7
Active Member
Very good to all. I've been customizing my Meteor and I'd like to extend the front fork to make it a chopper (to taste). I know the fork extensions. But I was thinking of making the modification by changing the front fork bars to longer ones and the rest to internal components if needed. I had been thinking about the Himalayan. Could you tell me if there is compatibility between the Meteor 350 bottles and the bars of any Himalayan models? If there is, would I have to change something else or just the bars? Thank you all very much.
In the early days of the Hima in 2016 I exchanged the front fork to that of the 535 conti which is like the UCE Bullet only sportier - it did fit (the reason was the vastly superior brake system by brembo).
I later repeated that with the 650 twin fork on a BS6 Hima from 2021 and it worked again.
But if the Hima fork works on a Meteor I do not know, but chances are good
**** YOU CAN READ IN YOUR OWN LANGUAGE BUT IF YOU REPLY YOU MUST USE AI FOR TRANSLATION TO ENGLISH ****
Thank you very much for sharing your experience!
That is very interesting, especially since you have successfully managed to adapt front forks from different Royal Enfield models.
My intention is slightly different. I would like to install the longer inner fork tubes (stanchions) from a Himalayan 411 into the original lower fork legs of my Meteor 350.
Both motorcycles use 41 mm fork tubes, but I do not know if their internal dimensions, lower bushings, top threads, and damper rod assemblies are compatible.
Ideally, I would keep the original Meteor lower fork legs, springs, and damping components, replacing only the inner tubes if mechanically possible.
When you carried out those modifications, did you replace the complete fork assemblies or did you swap any internal components?
Do you know if the fork tubes of the Himalayan 411 and the Meteor 350 have a similar internal construction?
Thanks again for your help!
I would look at the online spare part catalogue of Hitchcocks and compare what you see, that may already tell you all you need to know.
here is what Gemini AI had to say about it:
What You Need to Know​
  • Same Outer Diameter, Different Internals: While both forks use 41 mm outer stanchions (and Gabriel/Endurance damper-rod architectures), the internal parts are not interchangeable. The Meteor 350 uses inner tube part number RAH00187/A, which has different guide/slide bushing grooves, damper rod seating, and top cap thread pitches compared to the Himalayan 411.
  • Length & Travel Mismatch: The Himalayan 411 provides 200 mm of front travel, whereas the Meteor 350 has 130 mm. Even if the tube physically slid into the Meteor lower leg, keeping the original Meteor damper rods and springs would require massive preload spacers and would completely throw off the hydraulic rebound/compression stroke and oil volume.
  • Practical Alternatives:
    1. Threaded Fork Extensions ("Slugs"): Riders looking for a modest front lift on the Meteor 350 typically use screw-in top fork extensions (around 30 mm), though these shouldn't be pushed hard off-road as the threads are a weak point under heavy impacts.
    2. Full Fork Leg / Triple Clamp Swap: To actually gain Himalayan travel or length safely, you have to swap the complete fork legs (uppers, lowers, and internals together) and verify triple-clamp spacing, axle diameter, and brake caliper bracket alignment.
