Fuel pump replacement - cheap
Who is going to have the nerve of taking the fuel pump apart and then ride the bike with complete trust in it?
I bet only a handful of people.
If you can get a complete unit that would be better.
My 2 cents.
Speaking as someone who is silly enough to do it when it wasnt required, I could definitely reassemble it in 10 mins but I have yet to test that. ;)
My spare is in pieces
, Screenshot_20230529_200127_com.alibaba.aliexpresshd - Copy.jpgScreenshot_20230529_200137_com.alibaba.aliexpresshd.jpgScreenshot_20230529_200132_com.alibaba.aliexpresshd.jpg
because it is a Pig to pull apart, it was not designed to be taken apart!
It was Designed to be put together like so many consumables in our lives.
Holding the pump up to the computer screen, I just then compared it to a picture of one for a PCX-150 2012 and decided to buy it to see if I am right.
Big Gamble it is not, Amazing town want 14 times the price and I doubt theirs are Keihin.
Shipping time is stated as 15 Days, I will have more to say then
few pics for comparison
Well those pics show the unit was intended to have a fuel sender mounted, at least the half on the Inlet side. pic2.
Pic4 shows the Pump to confirm that the Outlet is Offset and the position of the wires.
So it may have been fitted to any number of Bikes produced in the last decade or so.
Keihin supplied the Throttle Body, ECU, fuel pump.
This could be made to fit!
It was bought for a Honda.
I dont know. we are not selling in India so check amazon.in or flipcart
Pressure is controlled by the valve on the housing not the pump
A lot of the electrical stuff on this bike is I imagine old Japanese technology, the pumps the ECU etc,
I have a Gauge that reads the Pressure of the pumps at the outlet and have used it for reference. I think it hits around 40 psi then drops a bit when it is Dead Headed into a Gauge with nowhere to go ( except of course thru the Pressure Relief valve into the tank)
True. Dead head is OK for reference but a gauge t'd in series with flow at a given rpm determines true operating pressure. We do a lot of EFI system rigging and adjustments at work and I was going to compare the two pumps on our equipment there.
Share the results, I would imagine that the flow would be very close between the OEM pump and the replacement.
Hello, I don't have the fuel pressure measure kit, so I'd like to ask if anyone try this:
as the manual says, (power switch off) disconnect the fuel hose from the pump, use an empty bottle to collect the fuel pump output > switch on/off for 3 times > then measure the amount of fuel in the bottle.
I only got about 140ml-150ml from my pump (scram 411 2022). Please try and share your result
p/s: my fuel pump seems to be error and I've already ordered replacement kit from HT, so waiting for the package for now.
Nope, have not tried it - but its an easy test, so valuable info!
I like my Pressure test ;)
I make enough of a mess as it is!
Although I have yet to suffer a Fuel Pump failure.
