Flow Testing
The Engineers I use now have the Flow Bench up and Running but this is expensive stuff and Time consuming also it would require a stock head to begin with, so will be very hard to justify, in the mean time I will just use the sexy valves from HMC with the Seats cut accordingly and only remove the Dags and imperfections from the Ports :unsure: . and perhaps increase the cc's in the Cylinder not the Head;)
Flow benching a stock head would be great to understand the starting point and then do a professional porting job and valve enlargment/recut to compare the before and after...
However i recon it is a really expensive job, specially if the prize to be gained is 2/3 horses max... Not worth the money...
