Engine protection plate breaks
This seems to be a recurring problem with Scram and Hima, the relatively thin alu plate breaks off on the rear right side. It seems enlarging the bore so the plate can be fixed without tension at least partially solves the problem.
However the material itself is cheap and a lasting solution would be one of the 3rd party steel plates. If there is any contact with the ground in all likelihood the stock plate attach point(s) will break.
