Different ECUs or mapping for the three models using J-Engine?
i was under the impression the TB/ECU combi in the Hunter/Meteor/Classic are the same and if you google spare parts this unit is often advertised as "for all BS6 models" - however at least the mapping would be different and because we poor souls can not change that it is important to get the right ECU with the right mapping for the respective model.
I also asked Bard what he thinks and here is the answer:
does Royal Enfield use different ECUs or different mapping in the ECUs for the 3 models using the J-engine?​
While Royal Enfield hasn't officially disclosed whether they use entirely different ECUs for the three J-series models (Meteor 350, Classic 350, and Bullet 350), it's highly likely that they employ different ECU mappings to tailor performance and characteristics for each model.
Here's a breakdown of the evidence supporting this:
  1. Engine Tuning and Feel:Despite sharing the same engine, each model exhibits distinct riding characteristics:
    • Meteor 350: Known for its smooth and refined power delivery, likely achieved through a mapping prioritizing linear power and a relaxed feel.
    • Classic 350: Boasts a slightly punchier mid-range, suggesting a mapping that emphasizes a bit more torque for a classic thumper experience.
    • Bullet 350: Offers a more raw and rugged feel, potentially achieved through a mapping that prioritizes low-end grunt and a more pronounced exhaust note.
  2. Gearing Differences: The three models sport different gear ratios to match their intended riding styles. ECU mapping would need to complement these gearing choices for optimal performance.
  3. Exhaust Variations: Each model has a unique exhaust system, influencing airflow and engine behavior. ECU mapping would need to account for these variations to ensure smooth running and emissions compliance.
  4. Manufacturer Precedent: It's a common practice among motorcycle manufacturers to use different ECU mappings, even within models sharing the same engine, to achieve diverse performance characteristics and suit varying customer preferences.
In conclusion, while Royal Enfield hasn't explicitly confirmed the use of different ECUs or mappings, the distinct riding experiences and technical differences between the J-series models strongly suggest that they employ tailored ECU calibrations to achieve their unique personalities.
false advertising?
I went to RE and found out: the company data base for spares actually gives the WRONG item number - even if you enter the serial number of the bike. It does add a remark on the side saying: "dismantle your bike first and find the actual part number on the part on your bike before ordering"
RE is such a fucked up company - I have no words
I also was offered a WRONG sample (this one is for the bullet). so YES. there are several different versions of the same hardware, each with different mappings.
Includes the Roll over sensor!
What a Throttle Body :rolleyes:
Hi sam, I don't know if this is useful to you, this is what is reported on my Scram
yeah, interesting, we can collect the different types here (will update as I get info):
RLT00187 = New HUNTER
RLT00142 = SCRAM
RLT00164 = new classic (Bullet) and old HUNTER
RLT00093 = Meteor (with speed limiter 115kmh and rpm limiter)
RTL00036 = Meteor 2021 (first model)
RLT00159 = early Meteor with speed limiter
RTL00065 = new classic
RLT00186 = ???
Has it been determined whether the limit is Revs or Speed?
Never fully tested revs, should have but 3 missed approaches with various tacho brands made me forget it.
I recently used my bluetooth connection app to check and revved it up to 6800rmp and could have gone higher but the engine was cold and I am allergic to the noise over-revving makes.
Speed wise the meteor got to 115kmh, with original and RLT00187 Hunter ECU, no difference.,
So for a Tacho we are still limited to OBD11?
Hitchcock's tacho kit is not cheap.
as mentioned elsewhere I tried 2 cheap aliexpress tachos both of which ran but where crappy in how they displayed the rpm (needle jumping all over the place) and the expensive Japanese Daytona version was a dud right out of the box, cost me almost 100 euros in shipping and taxes, had to return it.
Hello all,
Thanks for posting this thread. I wanted to drop by to let you know that the RLT0086 in the photo (which used to be, and is still listed as, RLT00086 in the RE parts catalog) is for the 2018 thru 2022 Himalayan. The 2023 Himalayan dropped the "bi starter" choke lever and switched to a new part number: RLT00189.
It makes me think they decided to drop a zero from production runs because they realized they were never going to need that many digits, hence why you have a part in your hand with RLT0086, rather than RLT00086. I don't, however, know what the mapping is on the Himmy ECUs so I can't comment on how it performs vs the Hunter, Classic, etc. I would expect that it would push a little more fuel due to the increased cylinder size on the Himmy vs the 350s.
my 2021 BS6 has no choke lever, also in 2018 and 19 the model still was BS4, the BS6 appeared in 2020. The BS4 does not have the ECU attached to the TB.
** we later found out: a few early BS6 models do have separate ECUs, only the maps are BS6.
A bit late to the game, but today changed my Bullet throttle body for the Hunter TB.
won't be on a Dyno for a few weeks when I don't expect much if any change.
First impressions ( apart from questioning myself) no neutral light, engine will not start with stand down and clutch must be pulled.
Engine light is on, I am hoping I can get it hooked up to the Dealers diagnostic tool, whether the light can be reset I am currently unaware. :unsure:
I bought a hunter TB for my Meteor. it worked immediately although not much of a change IMO.
