- Joined
- Nov 1, 2022
- Messages
- 1,228
21. May 2021, 13:00
The carb Himas of 2016/2017 are available in some countries but mainly in India. Their prices range from 60.000 rp to 130.000 rp depending on state of maintenance and km driven.
I want to list a few things I learned while I "updated" my four 2016 Himas (one of which I sold already) so you guys know what to be aware of.
Generally I think it is a very good idea to get an older model for a good price and invest the saved money into upgrades and stuff you like to add - vs. buying a shiny new one that will cost 100% more money and will only be shining for 3-6 month if properly used.
OK, here we go. Stuff you MUST change or at least be aware of:
- The first batch had a head problem. It was solved on warranty then but make sure yours was already fixed by the showroom tech.
- The first batch also had a problem with the swingarm - they would rip and break off at the contact to the droplinks - very dangerous. RE fixed that in 2018 so new swingarms are OK - change it for a new one, they are only 3300 rp. and while you do this make sure the droplinks and the triangle that attaches them are fully immersed ("packed") in water resistant high quality marine grease, not the shit RE normally uses for grease. Buy your own from Amazon and give it to the tech guy if needed.
- Look at the stator - if is is colored deep brown get a new one - actually get 2 new ones and keep one at home because they do fail with clockwork regularity about every 10.000km if you go on high speed runs on a highway. It probably is a heat problem. RE never fixed that and the BS4/EFI models have a different stator that does not have this problem.
- Absolutely take off the entire head/steering assembly and check the bearings. Most likely they will be worn. If you can afford it buy new ones from overseas, e.g. Germany or GB - the Indian SKF bearings are sub standard in hardness and keep failing. Also here use the best marine rated grease only and lots of it. If your model does not yet have the RE newly introduced steering seals make sure you get them and use them.
- Change the wheel bearings and grease the new ones. Never trust the factory grease is high quality and/or done properly.
- If the bike has over 30.000km remember the timing chain is due for exchange at that time.
- This is not specific to old Himas but to ALL Himas. Their frames can break at the head. re-inforce them like shown in this video:
- If you still have tyres from 2016 change them. Indian tyres are sub standard when new. When old they are outright dangerous because rubber hardens with time and even if the profile looks good the grip will not be good. There are no good tyres made in India for the Hima that I know of. Some say TIMSUN, made in Taiwan, are the best you can get. I have not tested them (yet).
- The seat likely will be kind of mushy if the bike was used a lot. Do not upholster it because the upholsterers mostly use cheap foam that is very uncomfy on long rides. Buy a good long distance seat new, there are various offers on Amazon. We use a brand from Delhi on all our bikes that is very good.
- Finally get a high handlebar. It is a big advantage in off road situations, the quality is better than OEM (which easily bends) and even on the road it is better to sit upright than bent down with the short OEM handle bar.
