BS6 Relays - problems & solutions
1,336
It seems the BS6 suffers from relay problems in particular with the fuel pump relay.
If you turn the key and the fuel pump does not purr - you know you have to look at the relays under the battery cover and the seat.
Should a failure happen far off the beaten path you can substitute the fuel pump relay with the side stand relay.
Notice the automatic shut off with an extended side stand will not work anymore, the engine LED will light up too (and stay lit even after you replaced the relays) - but you get home.
(this info was translated from the German tech support fb group)
