TPS/MAP Sensor
Well that's what I presume it is. 5 pins.
Does anyone have wiring diagrams that show the TPS wiring ?
In the Manual, if you can read it!
Now just the Colors :giggle:,
any ideas?
A wiring diagram of the NVX/Aerox 155 would solve the issue, however the only workshop manual I found online is very badly scanned and the wiring diagram is useless... 🤦‍♂️
May I ask of what use it is? I mean the BS4 has an accesible TPS and the BS6 has one glued to the ECU so this external one would not have access to that "hardened" ECU.
just curious ... keep up the tinkering ;)
For a 36mm Throttle Body that I have , My 500 has to beat your 500 :giggle:
Just playing with the piston pin circlips now :(
