Strange data showing in instrument display
anybody seen this before or knows what it means?
Error Code!
Easy, now you just need to know what error it is :ROFLMAO:
Call the friendly people at RE ,, Monday if it is not a Holiday;)
Error Code!
I figured its an error code but usually you only see that in the readout of the attached reader, not the instrument panel - and I did ask ranjeet, he has no clue (to be expected)
Push Reset!
Disconnect the Battery, that sort of stuff, does it run?
Push Reset!
I dont know anything - from the pic which is from the german fb group, i deduct it was not running at the time of the picture taken but i also assume it does start or else the guy would have mentioned that as well.
This is not an error code. This display also appears for about half a second shortly after the ignition is switched on. Probably a serial number, software version or something similar.
