reinforced clutch / springs plus 20%
A clutch spring kit for the Himalayan which brings plus 20% pressure on the friction discs. Due to the lever ratio only a mere 6% of additional hand force is needed on the lever.
The geometry , block height, number of windings and the wire diameter is identical as well as the overall length. The secret is the special spring steel which is non relaxating, so the spring keeps its initial shape.
Experience showed that already the IAT power sensor plus a 16T sprocket will bring the clutch to slippy behavior in high revs straight out so this might be a good option for the 477cc variant.
VAT only applies in the EU, rest of world is EU VAT free, this is 32,08€ ( -20% )
Shipment is up to 0.5kg: 13.-€ worldwide.
1 set is 135 grammes, so you can order up to 3 sets for 13.-€ shipment.
worldwide shipping:
clutch spring set +20%
This has been on for a year now. Can those who actually bought and used it give some feedback please?
Easier to install using 3 bolts, they supply 2.
Because the hub is not evenly compressed and the load of 6 springs is being compressed by only 2 6mm bolts that are stressed sideways as well.
Get an extra bolt and wing nut and modify ( ;) or destroy) a deep socket
And use a Cordless drill or a Tee bar.
OEM are Longer than HMC.
But different material?
