New 500 coming up ...
My 477 gets an upgrade
2 hours later
Got the wheels put on but since the ECU is not happy
low system voltage is normal, the starter motor hicks up every time now so I need 2-3 attempts to get rolling, the unsuccessful attemps tend to lower the voltage below 10 volts for a short time which creates that message. why the engine oil temp is high I do not understand, I have an external oil temp and it shows below 70C. That is a bit delayed but still over time it should show a higher temp if there was one.
I will install a new O2 sensor as soon as I get it - probably together with the new cat-less pipe. in the meantime the engine is running albeit not with perceivable power gain and certainly nothing like the carby 500 :unsure:
What App are you using to get Data ?
I would ignore the Data as unreliable.
Run it like you stole it and when it fails( if ever ) pull it down and have another look ;)
Cleaning has never given me good results
