FloridaMan
How many of you guys are having the heads machined when building the larger motors? Can I get away with tapering the edge with a dremel? Or do I need to have it properly turned?
Hello Dool Have you any photos of porting the head? ThanksI find it quite therapeutic, you may end up Porting it![]()
yes, but the effect is smaller, the head mod is way more effective to reduce compressionI might try that?
Ah, indeed!Every 1mm you add will require 2mm of chain.
