- Joined
- Nov 1, 2022
- Messages
- 1,228
Will be added to willy-nilly as stuff comes up:
ECU - Fundamentally, the engine control unit ECU controls the injection of the fuel and, in petrol engines, the timing of the spark to ignite it. It determines the position of the engine's internals using a Crankshaft Position Sensor so that the injectors and ignition system are activated at precisely the correct time.
Piggyback ECU's are wired to work with the factory ECU. ... Intercept the signal from the sensors before the factory ECU, and modify those signals so the stock ECU is “tricked” into making the vehicle behave the way you want. Example: Powertronic, Power Commander
TPS - A throttle position sensor (TPS) is a sensor used to monitor the air intake of an engine. The sensor is usually located on the butterfly spindle/shaft, so that it can directly monitor the position of the throttle. ... These modern non contact TPS include Hall effect sensors, inductive sensors, magnetoresistive and others.
QC quality control. something of questionable repute with RE
RE Royal Enfield, subsidary of Eicher Motors.
RWHP Rear wheel horse power, measured on a Dynamometer aka Dyno. Often only the acronym HP is used.
BHP Break horse power, measured at the crankshaft
H. or Hitch - short for Hitchcocks - an England based parts supplier for RE 3rd party stuff
The Red Box - A fully programable replacement ECU for the EFI up to BS4/2020. The best option to optimize engine performance because piggybacks can only do so much ECU cheating. Not available (yet) for the 2022/BS6 version.
MAF mass air flow sensor. On the Himma its mounted at the top of the Throttle body.
