those are millimiters, correct?Reversable it is and very noticeableView attachment 666 when gone!
Mmmm I like this solution less. Although it is true what you say, you risk lowering it too much and scratching the clutch cover...Yes Millimeters.
If you look at this pic you can see the easy answer, it involves bending the Lever ( with heat ) on the 2 fold lines to reduce the Upwards and increase the Outwards I think 6 to 8mm is possible there .
This would not look quite as Franky
Challenge accepted Easy, I will order a new one and when it arrives butcher it ( read , Make adjustments to it ) I recon it would be easy to bash it and get extra length.Mmmm I like this solution less. Although it is true what you say, you risk lowering it too much and scratching the clutch cover...
Problem is that the whole 18 shaft is welded, otherwise one could redo just the plate with same bends but longer...
