Forum Navigation
You need to log in to create posts and topics.
2021 model and Power Tronic
There seem to be issues with the PT if one has the 2021 model resulting in inexplicable idle cut-out issues that are not happening in the older models run with the appropriate PT model.
Make sure you order the correct PT model for your 2021 and read the thread that deals with this issue.
Dool has reacted to this post.
I have a 2020 model and my PT has been replaced by the local importer( New Zealand) Would not load up other maps. Have not to the shop for 2 weeks have been to busy with work to get back to them. Will call in this week and see if I can find out what the problem was.
sam2019 has reacted to this post.
It now seems PT does NOT offer an appropriately working 2021 Hima model ECU
Because '2021 model' depends a bit on where you are, are you referring to the model with the Tripper or the previous one (which is the 2021 model here in Aus)?
https://www.youtube.com/channel/UCqZS7_4U_Qp-qdBoWtZVDww/videos
YES, RIGHT, THE TRIPPER MODEL.
oldphart has reacted to this post.
oldphart
PT seems to have released a modified version for the TRIPPER 2021/2022 Hima.
However it is marked out of stock and the pictures they show you are from a different model so maybe this is just an annoucement and they are still in the development phase with this.
https://powertronicecu.com/product/powertronic-royal-enfield-himalayan-2021/
the real picture (Reddy's) is this:
read the discussion here:
https://forum.himalayan-tools.com/forum/topic/bs6-euro5-2021-ecu-locked-pt-working/?part=3
Now this PT model for the tripper version seems available. Another thing is you can check whether you have a choke/bi-starter on the left handlebar of the vehicle - if not its is BS6. I have emailed them, this is the reply:
We have a unit for that.
Here is the link below to the product page: https://powertronicecu.com/product/powertronic-royal-enfield-himalayan-2021-without-choke/
I am giving you a few instructions so that it would not throw any check light.
1) Please make sure, you switch off the vehicle before and during the installation. Also, 2021 has two additional ignition modulators. Please connect it to the harness and keep them behind the airbox under the relay set.
2) Keep in mind to not switch on the vehicle without either the stock coupler or the PowerTRONIC ECU connected.
3) Please do not disconnect the stock coupler or PowerTRONIC ECU while the LEDs on them are on. Disconnect them only after the LEDs are completely off.
Please get back to us if you need any assistance. We are happy to help you.
Regards,
Deepak A.
PowerTRONIC Support Team
